Disables the sending of summary refresh messages, instead of path messages, to refresh RSVP-TE path state for the specified VLAN interface.
| vlan | Specifies that summary refresh messages cannot refresh the RSVP-TE path state on one or more VLAN interfaces. |
| vlan_name | Specifies the VLAN interface for which RSVP-TE summary refresh messages are to be disabled. |
| vlan all | Specifies that summary refresh messages are to be disabled on all VLAN interfaces that have been added to MPLS. |
Disabled.
This command disables the sending of summary refresh messages to refresh RSVP-TE path state for the specified VLAN interface. By default, summary refresh is disabled. Specifying the all keyword disables summary refresh on all VLANs that have been added to MPLS.
The following command disables summary refresh on the specified VLAN:
disable mpls rsvp-te summary-refresh vlan vlan_1
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
